Windscreen washer front water tank
I'd think the "washer fluid low" message would be triggered by the sensor in the rear tank, so not helpful to identify a fault with the front sensor?
The 'WASHER FLUID LOW' message or illumination of the indicator is triggered by the rear washer fluid reservoir level sensor.
The rear washer fluid reservoir transfer pump will transfer the washer fluid when it receives a signal from the front washer fluid reservoir level sensor (i.e. when the front washer fluid level reduces to approx 1 litre) and continues until a signal is received confirming the front washer fluid level is full. This is why it’s helpful if a fault is identified with the front sensor (which may or may not be the case here).
As I mentioned earlier, when a 'WASHER FLUID LOW' message appears in the Instrument Cluster's message centre, the first display of this message, or illumination of the indicator, is accompanied by a 'chime' sound to alert the driver to the low fluid level.......I’ve asked the OP if he’s noticed this at all?
Chances are that it's the rear washer fluid reservoir 'Non return valve' that's causing the issue but before removing the rear bumper cover to get at it, it could be worth having a diagnostic check to see if this picks up a fault with the front washer fluid reservoir level sensor or anything else?
RPSN said:
Darren P said:
Thanks for these the manual was really useful.
Not sure I am brave enough to take rear bumper off. I don’t mind doing mechanical items like discs and pads etc. I think I need to find friendly independent near me.
No probs 👍
Before the bumper is taken off, it could be worth you getting a diagnostic check to see if it picks up a fault with the front washer fluid reservoir low level sensor? If so, it may be the case that the rear bumper cover doesn’t need removing?
However, when a low washer fluid level signal is transmitted to the Instrument Cluster (IC), a 'WASHER FLUID LOW' message is displayed in the IC's message centre. The first display of this message, or illumination of the indicator, is accompanied by a 'chime' sound to alert the driver to the low fluid level. Have you noticed this at all?
I've attached the TOPIx document ‘F-Type (X152) Bumpers’ which show the bumper covers removal and installation.
Not sure if you have the Coupe or Convertible so I’ve included info for both?
REAR BUMPER COVER (COUPE) - REMOVAL AND INSTALLATION (Pages 45-58)
REAR BUMPER COVER (FOLDING TOP) - REMOVAL AND INSTALLATION (Pages 74-90)
You can check for an Independent Jaguar Specialist near you here https://the-jaguar-specialist-register.com/ Just enter your postcode then click on the ‘Search’ box.
Thanks for the info appreciate all of the documents. Looks like a couple of specialist near me which is good news.
Hope you get it sorted.
Would be interesting to know the cause of the issue and how it was fixed?
Good luck with the independent, always good to find someone that you can trust with your car.
Yes be very interested what the final cause is determined to be.
I got the impression this is leaking out while parked up on a slope with the rear higher than the front, so assume this is not to do with the pumps and transfer system, but with water syphoning out through the air bleed hole in the front tank when the rear tank is higher than it physically. If the cars is off when it leaks then the pumps should not be running.
Still worth seeing if any faults logged of course, incase there is a faulty pump or something wrong with the pumping system that could cause the water to leak though from the rear.
Hi Darren
You've not had the car a month yet. Or should I say MY car!! I would ask Ashley Nickells, where you bought it, to look at it or at least ask them who to take it to. Even if you didn't get a warranty I think we can safely assume the fault existed before you bought the car, so the dealer will be liable and should pay. From what I hear about Ashley Nickells they are one of the nicest companies in the business so will probably not hesitate to help you.
Best of luck.
Captain Midlife said:
Hi Darren
Best of luck.
Totally agree with this. Any fault will be deemed to be pre-existing in the first 6 months and the seller will have to resolve at their cost. They may point out warranties and exclusions, to wriggle, but it's irrelevant as this is clearly enshrined responsibility in consumer law
While researching and considering bumper cover removal may be interesting I wouldn't spend time on it and just ask the seller to fix it
After reading this thread, I checked my handbook and the car.
I only have a filling position for windshield washer in the trunk.
Is the front tank a separate holding tank with a dedicated filling position, or simply a small in line sealed unit?
cj10jeeper said:
Any fault will be deemed to be pre-existing in the first 6 months and the seller will have to resolve at their cost. They may point out warranties and exclusions, to wriggle, but it's irrelevant as this is clearly enshrined responsibility in consumer law.
Definitely the best way forward.
An interesting topic.
I had thought about phoning Ashley Nickells. My challenge it’s a 3 plus hour round trip. So loose best part of a day dropping car off and picking back up. I will call them and see if they will pick the bill up for a local garage to me to repair. If they won’t I will probably go to independent locally. Not made of money but very time short☹️
It was a heck of a way to the dealership where I bought my own car so I see what you mean about the distance and time.
Hope Ashley Nickells are obliging and it works out to your satisfaction.
Hi I spoke to Lara at Ashley Nickells and more than willing to fix but I need to take car over there. I will probably take to a local independent over come weeks. When I know fault I will update. Thanks for all your help.
Not yet parking car on drive with front higher than back and it doesn’t leak.
I need to get around to booking car in to Jaguar Maidstone. You have just given me the nudge to do it today.
Hi finally got windscreen washer leak fixed. It appears system was full of gunk probably mixed screen wash residue seems to have affect the levels between the front and back tank. Both tanks cleaned out and pipe work. Also replaced screen washer pump and non return valve near wiper blade.
Now a quick update. The items I detail previously didn’t cure the leak when parked with the nose lower.
There is a non return valve on the exit of the rear tank that stops fluid running back from the front tank to the rear and it also needs the pump pressure to overcome the valve rear to front. My valve has jammed open and is not stopping flow either way.
Philskill said:
It's a guess but, If it were me I'd try the easier job of replacing the Non Return Valve on the rear washer tank. (item 7)
This valve will be designed to stop water returning to the rear tank, but it may need pressure from the pumped flow to open the valve, So may stop transfer of water under non pumped situations. Yours may be stuck open?
Thanks for this ! I was having the same problem. After I drove my car and it sat for a while, the front tank would keep filling until it came out of the vent, running the system dry after a few weeks. I thought it was the front level sensor, but after checking it manually and then w/ ohm meter, that wasn't the problem. The rear one way valve was stuck open. I put pressure on it both ways and believe I got it working again, but also routed a small clear hose from vent hole on front tank up to engine compartment. Now I can see if it does it again, and also can use vacuum or pressure on that hose to manipulate the rear valve again if needed. Thanks everyone, this was really perplexing but i'm happy to know what it is, or hopefully was. It's a $10 valve T2R7587 but hell to get to it, so I am going to see if this works, I'll update if needed. I love this forum. I have a 2014 V6-S since new, I'm retired and only drive 800mi p/yr. She's a garage kitty and I still love it.
