LED Door puddle lights
  • Start date Start date
Also Dezzy forgot to mention
I did not use the wire that came with them ... no need
Hello some night shots and in the garage ... for £12 very pleased, no idea how long they will last but seem good quality
all in all nice little cheap upgrade ... I have some more on order with a different GOBO (Lens graphics)
Just had an instant refund for the, rather expensive version here:
http://www.ebay.co.uk/itm/2x-Ghost-LED-Door-Step-Courtesy-Shadow-Laser-Lights-For-Jaguar-F-TYPE-2013-2015/253029894293?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2057872.m2749.l2649
Don't buy this version. Although nicely made and have the ring around the logo, they are too long to fit into the slot.
For those not sure, there's no need for a screwdriver with associated risks of damage, from the back of the door, i.e. opposite side to the hinge, it merely requires a thumb nail under the edge and it just eases out. Another tip, the bulb will stay lit and get quite hot while you're deciding how much effort is needed to release the small plug. The bulb is the small capless 5w version and just pulls out, I griped it with some kitchen paper.
HTH
kaspa, could you provide a link to your source please. Presumably they fit ok?
Scorchio595 said:
Nice, I fitted the ones with the Growler Badge with Red detail as in the grille front badge, they do look great in the dark
The Growler ones aren't as clear as i thought they were going to be. I see you can turn the unit , i presume that's for which way you want to place it, nothing to do with picture display resolution
Hello ...
I have gone LED blue .. suits my car
I've got those ones but without the circle around the logo. This is what I bought on ebay...
https://m.ebay.co.uk/itm/2x-JAGUAR-F-TYPE-CREE-LED-PROJECTOR-CAR-DOOR-LIGHTS-SHADOW-COURTESY-LASER-LOGO-/192185123645
Alasdair 63 said:
Kaspa ‘did you add the illumanated tread plates or were they a factory fit
Hello ... the tread plates were factory fit :)
Thanks for this link, I bought the Growler version and messed about at the weekend and couldn't get them to fit.
Bought replacements based on your link and slotted straight in and look great - cheers!
Just fitted these and am pleased with the result. Perfect fit and only took 1 minute per side and even used to original connector.
The ad on Ebay, item number 253029425914 shows them to have red which seems to be missing from mine but overall, quite happy.
Don't know why the picture is upside down, it's correct on the car and can be adjusted which is handy.
Hello
I bought a pair of puddle lights (growler type) after reading several posts on here, as I thought they looked good. Now this is where I need the help of those of you who have fitted them. How did you unplug the original light. Most posts I have read, on here say its an easy job, but I cannot unplug mine. One member said unplugging was the hardest bit of the job and mentioned that a lug had to be pressed to release it, but I cannot find any thing to press. Can anybody help. Thanks.
Keith
I purchased a set of puddle lights on Ebay a few weeks ago. They were great for about 2 weeks then my interrior lights stopped working. We did some research & ended up reinstalling my factory lamps & the interior lights work again. I loved them but wish they lasted a little longer.
Thanks for the info jgaxkr. Sorry yours failed. I noticed there were quite a few different types of lights, and prices, on e-bay. I bought mine from pixelprice (£14-95), they are listed as 5 watt, the same as the original bulb. They seem to be well made, time will tell. Did you have trouble unplugging the original light?...is there a lug or something to press to allow separation or is the plug just a tight fit. I have pulled quite hard and feel if force it any harder some thing will break. I do not want to damage the plug or wiring loom. Any tips appreciated.
Ninetails,
I seem to remember that there is indeed a button or lug to press in to release the connector from the Puddle Light (or at least there was on my convertible).
It's been a while and I didn't take any photos, but I agree don't tug on it the connector because you will break something!
Seacourt
Seacourt said:
Ninetails,
Seacourt
Seacourt
Thank you for the reply.
