smart TOP Roof Controller
Fixy Wixy
SmartTop Comfort roof control for Jaguar F-Type convertible £225 Posted - currently £399 new
smarttop
The SmartTOP roof control unit allows you to open or close the convertible top while driving at slow speeds. It works similar to power-windows and opens or closes the roof automatically at the touch of a button. It is not necessary to stop the vehicle and pull the handbrake to operate the roof.
Designed For:
Jaguar F-Type Convertible MY 2013+
One-Touch power convertible top
"One-Touch" convertible top operation allows your top to open or close automatically.
Invert switch logic
Direction of center console top switch can be changed is desired.
Windows close automatically
After closing the top, all windows roll up automatically.
Top convenience mode
Turning the ignition on or off does not interrupt convertible top operation.
Remote control of convertible top
Open/Close your convertible top using the original factory remote control key / key fob.
Separate window control
Raise and lower the windows separately by remote without activating the top.
Window positions programmable
Raise windows after opening top.
ECO Disable
Automatically disable ECO mode when starting the car.
Exhaust Flap/Valve Memory
Memorise last setting or always open exhaust flaps.
Individually programmable
Configure functions of the module to meet your personal preferences via our signature blinker setup menu.
Passive / Invisible mode
Turn the whole module off with an easy key sequence. Ideal when letting someone else drive your car.
Valet Mode
Lock the top in the closed position with a quick key sequence when needed.
Reversible plug-in installation
Remove any time allowing sale or return of a leased vehicle in its original condition.
Plug-n-Play Wiring harness
Custom designed plug-in-between wiring harness for extremely simple and quick installation included.
USB Port for easy setup / updates
This module can be configured and updated using any Mac or PC.
E13 Certification: E13 10R – 03 10070
Standby Power: <0.1MA
Dual Color LEDs: Yes
