Rear light units 2016 convertible
Apex
I’m in the process of gathering up parts to change the rear lights on an American f-type convertible to the amber direction lights in the ECE versions.
Does the light unit have an outer section and an inner section that joins together to form one wider wrap around light?
If so, then I think the direction indicators are in the outer section? Can anyone confirm this? I guess the inner sections don’t need changing?
I need both left and right sides. Does anyone know the part numbers?
Thank you
I now see that the light units are one complete unit. I’ve successfully swapped the US lights with red indicators for ECE ones with amber indicators, and without any coding or wiring mods by me.
It is possible that the car had already had some regional coding changed to GCC spec as the headlights were already changed and functioning correctly, including the DRL lights that must either go out or dim when the indicators are in use.
One thing to be aware of is that US cars do not have the PSS pedestrian safety system bonnet airbags that is required in Europe since 2015. However under a Single Vehicle homologation for relocation of dwelling, this requirement is exempted.
