I’m in the process of gathering up parts to change the rear lights on an American f-type convertible to the amber direction lights in the ECE versions.
Does the light unit have an outer section and an inner section that joins together to form one wider wrap around light?
If so, then I think the direction indicators are in the outer section? Can anyone confirm this? I guess the inner sections don’t need changing?
I need both left and right sides. Does anyone know the part numbers?
Thank you
Thank you
