Cotswold Polaris
Well done WShudds, great Xmas present to yourself
Cotswold Polaris said:Well done WShudds, great Xmas present to yourself
WShudds said:He could not believe the sound it made when the engine is switched on and said this would definitely win the Carwow exhaust contest!
scm said:WShudds said:He could not believe the sound it made when the engine is switched on and said this would definitely win the Carwow exhaust contest!
Not if there's a V8 there! But it'd be a very close second ... :lol:
WShudds said:scm said:WShudds said:He could not believe the sound it made when the engine is switched on and said this would definitely win the Carwow exhaust contest!
A very honourable 2nd place in that case! Another quick feedback on the pirelli P Zero tyres. They have 5mm thread left on the rear and 7mm on the front. I don't know if they're the OE version but they surprised me. Online commentary seemed to imply that the tyres want to kill you and I thought of myself drifting on M1 all the way back to Huddersfield
Not at all. I pushed the car in dynamic mode around bends and everything was pretty safe despite the pouring rain and 6C. I barely managed to break traction coming off a junction once but that's it. I was already coming to terms that'd have to spend 800 on new tyres right away.![]()
WShudds said:Another quick feedback on the pirelli P Zero tyres. They have 5mm thread left on the rear and 7mm on the front. I don't know if they're the OE version but they surprised me. Online commentary seemed to imply that the tyres want to kill you and I thought of myself drifting on M1 all the way back to Huddersfield
MajorTom said:Brilliant exhaust note isn't it? One important and super simple mod to get to hear the exhaust better is to block the utterly pointless symposer. There should be a thread or two about that on here.
The temperature gauge can be a bit confusing at first sight. This is the way it should look when it's fully up to temp. That is, the little white arrow should be right in the middle. Didn't it look like this?
Read on some tyre sites for 3.0L V6 is 36psi? Though if you are reading the tyre label as 37 I would say it’s more accurate. My own certainly states 37 and if filled to 37 when cold that will raise by a few pounds when driven. For extreme high speeds i.e plus 155mph the recommendation is higher. (In the UKWShudds said:MajorTom said:608.jpg
Just a quick update, the temperature reading is indeed OK
Does anyone run on 19" wheels? I had to inflate the tyres today as the warning came up at 32psi. I put them on 37 psi as indicated in the dash but wonder if anyone has a different opinion?
Thanks.
T50 YOX said:Welcome to the club nice looking car if you’re only in Huddersfield why not come and join us at the jaguar breakfast club at the rhubarb triangle pub 2nd Saturday of every month 10am next one 13/1/2024 quite a good few selection of FType s’more than welcome cheers Tony from Barnsley![]()
scm said:The dash display will show the recommended pressure in brackets under the actual reading. I've found mine drop pressure when the temperature drops, so when we have a cold spell, I have to reinflate the tyres to 37psi.
simpleR said:As long as that is the car you want then welcome to the club. However you seem unsure on the spec against what you wanted.
There are 214 manuals out there somewhere. Of which only 68 are the more desired S (380PS).
2012 Total = 0
2013 Total = 0
2014 Total = 0
2015 Total = 60
2016 Total = 63
2017 Total = 33
2018 Total = 46
2019 Total = 10
2020 Total = 1 (older model)
2021 Total = 1 (older model)
