Hi All, after a catastrophic rainwater leak into the tailgate area of my F Type S (2014), some serious damage has been done to the wiring. My audio, SatNav, Phone, right side blind-spot indicator and tailgate release no longer function and the problem appears to centre on damage done to a loom of 8 wires that leave to tailgate well fuse-box (via top, grey, connection box). This small loom of wires run from the fuse-box, across the steel floor to the left hand side of the (main) battery, and then briefly enter a much larger loom/hardness of wires. After about 20cm these wires then leave the larger loom and run across the rear of the luggage space area, with one wire feeding into the tailgate release mechanism, one feeding a right hand light (I think) and the rest entering a circular connecting block at the rear right hand side of boot area flooring. I've looked at several wiring diagrams (through links on this forum and another) but haven't been able to establish the part numbers for either the small loom (those wires that exit the fuse-box) or the much larger loom, (it's possible that the smaller loom is supplied as part of the much larger loom).
I've got an auto-electrician who's willing to attempt a repair but he wants me to supply the parts. I've searched on-line/eBay etc for a loom/looms that look similar but without success, and without part number(s) I'm totally stuck at the moment. Can anyone help me with this?
