I've been having some issues with my Jaguar F-type for a few months now.
The issue is related to some battery drainage that's cause all sorts of error being displayed, and also the roof stops working whenever the error pops up.
As the car is under warranty I took to my local Jaguar main dealer. They first came back blaming the battery and wanting to charge me £500. I told them the battery is brand new. They then said as it's not an authorised Jaguar battery they can't say if it works or not. The battery was changed and the error was still coming up. I wasn't charged for the battery. The next time they said it was the way the trickle charger was connected.
They wanted to charge me £250 to change one cable. When I sent them an official document to prove I wired it correctly they dropped that idea.
Now they're saying it's the big cable that connects the alternator to the battery in the boot. They're saying they found a little corrosion on the cable(Corrosion is not covered under warranty) and they believe this is preventing the alternator from charging the battery when the car is running and that's why I get the errors. I tried to explain to them that I still get the error, even when the vehicle has been left standing while plugged into my trickle charger. So, the vehicle hasn't been driven and the battery has been fully charged, but the error still appears. In fact, the error goes away after starting the engine and letting the car run for a few minutes. This proves the alternator is doing its job.
I e spent nearly 1 hour on the phone to the engineer, and after the conversation, he even said he now doesn't think the cable could be at fault.
They're now still insisting the cable would need to be changed. I said OK but I would want my £1200 back if the problem is not resolved after the cable has been changed.
They came back and said no refund will be given after the cable has been changed and the same error returns.
Due to COVID, JLR have decided to shut their customer service centre and sending them emails is just a waste, all you get back is some bull email to say they're dealing with it.
Wondered if I were to pay using my credit card can I can claim a chargeback if the problem returns?
Really sorry for the long tread but I've had enough with this dealership. Unfortunately, the other Main dealer near me is also the same franchise as the current one.
