nakatomi.plaza
I just want to preface this by saying, this is not a long term solution but at the moment I have an trickle charger with an AGM cycle hooked up with the jump posts on my 2016 V6S.
The charger itself is displaying the the correct lighting but the car blinkers and trunk lid lights are blinking in a pattern... flash-flash, 3 seconds pause, flash-flash, 3 second pause, on repeat.
I haven't seen this behavior described anywhere else on the forum and was wondering if this is a) normal, or a b) a sign of a problem with the battery. The battery is fairly dead. The info screen says the battery is low, start the engine but there's not enough juice.
Thanks in advance.
Thanks in advance.
