Globle window close after battery replaced
Bobbyv
So had to have the main battery replaced kept getting the low battery warning as it's 9 years old I'm not to sad.
After connecting the new AGM battery the one touch window close wouldn't work also globle close and opening the convertible, windows not going back up.
Tried doing the normal window reset still not working, lots of looking on the Internet and forums and finally found a post on this site.
Basically engine on door closed open window a bit close window release switch then operate switch to close 10 more times you must hear the click each time then do the same but in the open position then the same for the passenger side you can do this from the drivers door switch.
This combination worked for me and I had tried everything.
Thanks guy's keep up the good work as I had it booked into Jaguars £240 just to look at it and then tell me how much to fix.
Blimey, that’s bad luck - you only had it replaced 1 minute ago ;)
Glad to hear you found a way to fix it, these things can be infuriating.
