Carl9872 said:Yes, I've seen the MOT history, appears to be lack of use rather than hard use but you never know with a used car.
Nearside Front Brake disc worn, pitted or scored, but not seriously weakened inner face heavy surface corrosion due to been stood possibly may wear off with use. (1.1.14 (a) (ii))
Offside Front Brake disc worn, pitted or scored, but not seriously weakened inner face heavy surface corrosion due to been stood possibly may wear off with use. (1.1.14 (a) (ii)
cj10jeeper said:Also worn out the tyres at 18k isn't a gentle driver/life.
scm said:cj10jeeper said:Also worn out the tyres at 18k isn't a gentle driver/life.
18K not a gentle driver? Mine never last longer than 10k miles, and that's been the case with all 4 Jags I've had. The fronts on the RWD XKRs lasted a bit longer, but the rears, always 10k miles.
Carl9872 said:Thanks all, I'm not progressing with the purchase of this one, I never got to drive it but it looks lovely !
