Hi everyone,
I'm currently considering buying a 2019 Jaguar F-Type P380 with 56,000 km on the odometer. During my inspection, I noticed some concerns and wanted to get your insights before making a decision. Here are the details:
When the seller started the car (cold start), I noticed a tic-tic noise coming from the area near the compressor. Could this be the belt or something else?
After a few seconds, the motor seemed to settle down, but the tic-tic noise persisted. There was also quite a bit of noise coming from the front radiator area, but I assume that’s normal for this model.
The owner mentioned the car recently had an oil change, but there's no verified maintenance history. Previous maintenance was done at random garages, and there’s no proof of past oil changes.
The lack of a clear history is a bit concerning for me, especially since I'm buying this car in South Korea, where Jaguar dealers no longer operate. After-sales service is handled by Range Rover here.
The car had a battery drain issue when I arrived. They had to replace the battery to start the car.
I inspected for corrosion near the injectors, but it was hard to see clearly.
There was no white smoke from the exhaust after running the car for 5 minutes.
The car is listed at 58 million KRW, which is approximately $43,800 USD.
I've also attached a video link of the cold start so you can hear the noise and provide feedback.
https://youtu.be/oaKkmFAL3XQ?si=53ZY3k_g8LwOK6YS
I’d love to hear your thoughts on whether the noise is something I should be worried about.
Thank you so much for your help
