Do anyone know how to set the wipers to the service position? I've tried to follow the user manual:
Before changing a wiper blade, the wiper arms must be set in the service position as follows:
But it did nothing apart from normal wiper operation.
- Make sure the ignition is switched off.
- Switch the ignition on, then off again.
- Immediately pull the wash/wipe control toward the driver, as if to command a single wipe. Hold this position while switching the ignition on again. The wipers move to the service position.
- When the new parts have been fitted, switch the ignition off. The wipers return to the park position.
