vibrating/buzzing from centre vent
ml276
hello, couldnt see any previous threads on this
have had the car for a few months and never actually driven with the centre vent deployed, until a few days ago
during this journey started to hear a horrible buzzing / vibrating noise coming from the centre vent area whilst the AC was on. dissapeared as soon as the AC was switched off and the vent closed
cant remember the exact speed it started at, but certainly seemed to get worse with increasing speed/revs
wasn't captured very well on the dash cam, but the noise is certainly reproducible
has anyone experienced this or got any ideas as to what the problem could be? :?
@ml276.
Had the same issue for 10 months. Turns out to be two fuel lines vibrating. Left hand side of vehicle, just in front of exhaust muffler..
-- just noticed you have a MY16 V6, could be another reason --- :(
Took my dealer several days, left the car 3 times for weeks with them... .. you must be happy with my post.. :lol:
They fitted the two pieces of black rubber hose to prevent contact with the body.
Dan_Veluwe said:
@ml276.
excellent :shock:
i am currently in arguement with dealers over vertical scratches in drivers/passenger windows. so i'll bring this up when it finally goes into them and show them your post (hopefully reducing the number of weeks it is with them :roll: )
thanks for the input :)
is the centre vent meant to rise up everytime you start the car, regardless of whether you have climate/ac on ??
You can choose to have the centre vent "always open" or set it to "auto" in the menu (in centre screen---general settings > climate > centre vent then choose auto or always open). If you choose "always open" it will rise when you start car and stay up until you switch off engine. If you choose auto (in the menu), it will come up automatically (when heating system is turned on by pressing auto switch on dash) when necessary, and blow cold air (only) to cool cabin down to maintain the cabin temp you have set. Even if you have selected "auto" rise, in the climate menu, you can also raise the centre vent by selecting the heating/ventilation on the centre screen (from home screen) and then selecting upper cabin air flow. This will then raise the centre vent and blow hot or cold air depending on the temp you have set. I find with centre vent blowing hot air is the best setting for heating the cabin up quickly on cold days.
ninetails said:
You can choose to have the centre vent "up all the time" or set it to "auto rise" in the menu (accessed through steering wheel buttons). If you choose up all the time it will rise when you start car and stay up until you switch off engine. If you choose auto (in the menu), it will come up automatically (when heating system is turned on by pressing auto switch on dash) when necessary, and blow cold air (only) to cool cabin down to maintain the cabin temp you have set. Even if you have selected auto rise, in the steering wheel menu, you can also raise the centre vent by selecting the heating/ventilation on the centre screen and then selecting upper cabin air flow. This will then blow hot or cold air depending on the temp you have set. I find with centre vent blowing hot air is the best setting for heating the cabin up quickly on cold days.
Thanks for that useful info!
Will take a look at the settings next time :)
I have corrected my original post, but the incorrect info is still showing in the Quoted post (ml276) so I thought I had better re-post to high light the correct info.
Cheers ninetails, i can see it 😄👍🏽
