V6 service & MOT cost
badger said:
the same with the spark plugs how would you know if they were replaced? you cant see them, you just have to trust they were done.
You could ask to see the old ones so you can see how bad they were. Of course, you have to trust them not to keep an old set to show customers .... The benefit with my independent is it's a small outfit and there's nowhere to hide while they're doing the work!
kaspa said:
Hello
Just had my 3 year old F Type service today and the cost was including its 1st MOT was £531.63
Also would you believe a car only with 4089 miles failed the MOT !!! also they tried to update 251 intouch pro but it refused to let them as there is a new version coming out soon ?
all the best
Kaspa, is that because you hadn't done enough miles👍😂
My Evoque used to get flashed by oncomers when new, when I checked the headlights they were pointing into the sky! Does make you wonder how they are so bad from new.
badger said:
DaddyDarren said:
Including plugs that sounds a good deal. I’ve had my looked after by main dealer for last three years. Last year should have been plugs, they didn’t mention this until I collected it & it would’ve been £400+ just for plugs. Yes, ridiculous but that’s main dealers. Some say plugs don’t need changing at these low mileages but, as you say, no harm done.
Possibly going to a recommended Jaguar independent this year. It’s only done 21k but I want everything doing,, including diff oil &, at Timbo’s suggestion, gearbox oil too. It’s a much cherished keeper so want to keep it tip top.
that is poor from a main dealer, if the service specified spark plugs as a service item it should have been done unless you had told them not to. also £400 extra for plugs is steep.
The only conclusion I came to was low mileage & yes very expensive. Will see what independent says, whenever that may be ☹️
Thread cleaned.
Let's get back to discussing the topic at hand rather than a rambling expletive-laden rant about a particular dealer.
Thanks.
PhilB said:
Thread cleaned.
Thanks.
Always miss the good bits. Is MM back 😁
Do you think this quote from the main dealer is too much ?
"Officially the 4th service is the major one so that’s what we would recommend. On Jaguar menu pricing its coming out at £692.28 but I can offer it you for £599 including VAT. The service includes replacement oil, oil filter, pollen filter and two air filters along with a full vehicle health check."
as I have today put the car back on the road thought I would get the oil changed, so had engine flush, new oil filter and oil, rear diff oil changed and the troublesome electrical block cleaned and treated, all in £167 and I supplied the diff oil.
pleased with this deal
I paid £479 inc VAT last year at my local franchised dealer for the 4th year service and with all the Items you mentioned.
Just managed to get mine booked in with Matford Exeter. Last week in June so only 3 weeks late. Only 1600 miles between services this year😢 must get out in her more.
5 year service is interim and £325 plus £100 for plugs.
Mine car now needs the 5 year service.....
Stockport Jaguar quoted £459.
Is this correct for an interim service?
And what do you get for your £459?
Fixed price 5 year service is £325 as shown on the official JLR bulletin a few posts up.
Difference will be the price for plugs.
Check with them that they are actually changing the plugs for this price otherwise it's not the correct price and check it also includes VAT!
simpleR said:
Jaguar use EMaC for their service plans.
You can contact them directly to get quotes for service plans. This saves dealers adding their own mark up.
Contact EMaC at [email protected] or alternatively call them on 0844 800 6826 although unsure on times (used to be Mon-Fri 8am to 6pm).
About to email them to see what they can do for mine. Looking for a 4th/5th/6th plan.
Thanks for the info. Am in same situation so have emailed for similar quote
Oddly the quote I got back was more expensive than using Jaguars fixed service price plan.
So next year I've chosen these people.
https://www.mgajaguar.co.uk/jaguar-services/
Reviews seem good. Will monitor over the coming year.
I've just been quoted £522 for the 5 year service on my V6S, £200 for plugs seems excessive to me! Think I will be questioning that one
SESH said:
Just had my V6S 5 year service completed by a main dealer for £265.19 inc VAT excluding plugs.
Wow, that's cheaper than the fixed price interim service! I've just managed to get some OEM plugs cheap, I am sure they will be pleased that I am supplying my own... :lol:
