You should be able to use the loom from your current seats. I suspect they are 6 way electric adjustment like your current seats.
They should be plug and play with no other mods required. Mine were, the only thing I had to have activated was the climate option.
There will be an option to activate the cushion tilt to make them 8 way, but you will then need to get the option activated.
