Under tray alignment - NACA duct
leedsjag
Hi
Had my under tray off today. On replacing it, I notice the NACA duct doesn't exactly line up with the inlet above - and there doesn't appear to be any clips.
Is this right that it's just "there or thereabouts"?
Ta
It was designed to be aligned up.
Did you notice if it was the same before you removed the undertray? If it wasn't, it’s due to the refitting process.
Is there any ‘give’ in the duct so that you can move it slightly into position?
If it was the same before you removed the undertray and you haven’t had any issues then I wouldn’t be too concerned about it.
I recently posted the undertray (Radiator Splash Shield) removal and installation TOPIx file here....
https://www.ftypeforums.co.uk/viewtopic.php?p=68161#p68161
