Supercharger Whine Inhibitor removal.. Anyone tried this?
Chrissyg
Was just wondering how I could get a bit more supercharger noise on my V8S, when a google came up with this. Has anyone tried one? Does it work? Easy to install yourself?
Couldn't find anyone referencing it on here..
http://www.davidapplebyengineering.com/Shop/ProductDetails/Jaguar_F_Type_V8_SC_whine_inhibitor_Pipe_Delete/785
Thanks in advance,
Chris
From the brief description and picture that seems very overpriced for what would essentially be a hose and clips (?)
Must be more to it or I have misunderstood the wording
Diy option couple of hours and around 400 pounds using itg air filters
Or the david applepy options
Tbh not sure the whine wouldnt get a bit annoying after a while
You're right.. does seem a little bit pricey doesn't it if it is just that. I'll go and take a look at the air intake system later and see if there's anything more to it on my car!
I don't fancy an aftermarket air filter personally, more noise that way means more airflow, more airflow means bigger holes in the filter and bigger holes means more dirt gets in - just my opinion :) Hence why I fancied a replacement hose which seems a fairly straight forward fit.
I'm not trying to make the whine really loud, I'd just quite like to hear it a bit! Don't think it'll be annoying for the miles that I do a year.
Thanks in advance,
Chris
Weird, I searched and my own post came up!!!
https://www.ftypeforums.co.uk/viewtopic.php?f=27&t=3201&hilit=supercharger+whine
Thanks Tel. If I've read your thread right, it's a new intake you've fitted which I'm not super keen on. Was more wondering if the kit I liked which seems to bypass/remove the whine inhibitor.
Yep, now sucks fresh air through foam filters Pre MAF.
No new intake, that says the same post MAF - Thats' the next mod!
Some night time reading for you...
https://www.jaguarforums.com/forum/f-type-x152-72/more-blower-noise-176192/
https://www.jaguarforums.com/forum/f-type-x152-72/improving-stock-intake-more-flow-lower-iats-more-sc-noise-200168/
Thank you! There's certainly a bit to read in there! It does look nice doesn't it.. but I suspect that'll be £300+ with shipping to t he UK unless anyone knows of a UK retailer?
