Lunar said:Well PPF isn't without its own potential issues over time so after 5 years of the car being peppered I took the other option and recently had the nose cone fully taken apart and resprayed - perfect match to the Lunar Grey Metallic.
I spent just over a grand, but that included a repair to the driver's seat bolster and deep cleaning and re-dyeing both seats, along with a couple of touch ups done properly - i.e. thin paint layer, over fill with varnish, wait a week to harden, polish back down. Sprayed metallic stands vertical from the body, whereas brushing can easily leave it sitting flat and therefore looking darker.
Being a bit of a photo geek I have a slight aversion to plastic, be that in lenses, filters, spectacles (glasses to the younger generation), or PPF - I'm probably just old fashioned but hey!
I had brilliant service all round - this place in Farnham must be one of the best in the country and if you catch them on a good day their passion may lead to a tour of their very high tech facilities...
https://www.premierpanelskills.co.uk/
Lunar said:Well PPF isn't without its own potential issues over time so after 5 years of the car being peppered I took the other option and recently had the nose cone fully taken apart and resprayed.
Robcat1978 said:Cost will depend on condition of existing paintwork (ie swirl marks etc) whether a correction detail is required beforehand. Surprising what the bright lights show up!!
I would recommend PPF
Tel said:Lunar said:Well PPF isn't without its own potential issues over time so after 5 years of the car being peppered I took the other option and recently had the nose cone fully taken apart and resprayed.
Can you elaborate on the potential issues?
Lunar said:Tel said:Lunar said:Well PPF isn't without its own potential issues over time so after 5 years of the car being peppered I took the other option and recently had the nose cone fully taken apart and resprayed.
Well if you get a sharp stone hit that pierces the PPF it makes the edge show and mending it tends to be replacing the complete PPF section.
And if you have a small section that doesn't have a wrap-around edge, such as a patch at the rear of the sills, then over time the edge tends to get a bit worn and hard to keep reasonably invisibly clean.
Each to their own though - no right or wrong way to go about it.
