MJJC Foam Canon
fozzy
I figured with the new motor I needed to up my car cleaning game so purchased the MJJC Foam Canon Pro.
First time using a foam canon. I went with the Bilt Hamber auto foam. The instructions for mixing were a bit cryptic so went off a YouTube video and went 400ml product + 600ml water. There was enough to do the F-Type and my missus' A Class. I probably wasted some too getting the technique right.
This was with a little Karcher K3.
I've heard good things about the Bilt Hamber but you have to work out the dilution based on volume used per litre or something to get the best results (it has an acronym but I can't remember it - Panel hit volume or something). I'm going to order some when my current snow stuff runs out.
Incidentally, if anyone (like me) doesn't have easy access to electricity and water where their car is parked, I bought a rather excellent cordless USB powered snow foamer from carbon collective.
If it helps, this is the video I watched https://youtu.be/idgSnTghvqA.
I think I could afford to dial back the product a bit more as it was plenty foamy enough.
