MikeM said:A lot of F type owners don’t use their car as a daily driver so you can find quite a few c2019 cars under 20k miles. Think though there are equally numbers with high 30 to 40k miles. There are a few faults that can appear such as failed Y pipe and DRL, although not sure this is an issue with 2019 cars? Some members on here will certainly know of this and more. As long as it has a complete service history (get the vin no and check on www.jaguarosh.com. Also MOT history and do a “car vertical” or similar history check. If all looks good and the price reflects the mileage, consider investing in a decent warranty cover. Used to do 30k miles a year in company cars and hand them back at 60/90k with no major issues. Fact is these cars should be good for a few hundred thousand miles if well treated and maintained, just nobody uses them that much.
One owner with a complete service history and a Jaguar warranty, always a good starting point. If the spec and price suits you, what will be your annual mileage and how long do you think you’ll keep it for. If a reasonable amount of time certainly consider going for it and keep the maintenance and warranty up.ogscu said:MikeM said:A lot of F type owners don’t use their car as a daily driver so you can find quite a few c2019 cars under 20k miles. Think though there are equally numbers with high 30 to 40k miles. There are a few faults that can appear such as failed Y pipe and DRL, although not sure this is an issue with 2019 cars? Some members on here will certainly know of this and more. As long as it has a complete service history (get the vin no and check on www.jaguarosh.com. Also MOT history and do a “car vertical” or similar history check. If all looks good and the price reflects the mileage, consider investing in a decent warranty cover. Used to do 30k miles a year in company cars and hand them back at 60/90k with no major issues. Fact is these cars should be good for a few hundred thousand miles if well treated and maintained, just nobody uses them that much.
Thankfully the car comes with approved used Jaguar warranty, although the sticker price definitely reflects this by being priced a bit higher than normal. It has the new Y pipe and has had 1 owner from new, full service history.
MikeM said:One owner with a complete service history and a Jaguar warranty, always a good starting point. If the spec and price suits you, what will be your annual mileage and how long do you think you’ll keep it for. If a reasonable amount of time certainly consider going for it and keep the maintenance and warranty up.ogscu said:MikeM said:A lot of F type owners don’t use their car as a daily driver so you can find quite a few c2019 cars under 20k miles. Think though there are equally numbers with high 30 to 40k miles. There are a few faults that can appear such as failed Y pipe and DRL, although not sure this is an issue with 2019 cars? Some members on here will certainly know of this and more. As long as it has a complete service history (get the vin no and check on www.jaguarosh.com. Also MOT history and do a “car vertical” or similar history check. If all looks good and the price reflects the mileage, consider investing in a decent warranty cover. Used to do 30k miles a year in company cars and hand them back at 60/90k with no major issues. Fact is these cars should be good for a few hundred thousand miles if well treated and maintained, just nobody uses them that much.
I have actually just noticed that the first service wasn’t completed until 22 months after registration, and the 24 months service is 36 months after registration. The services that follow don’t seem to amend the mistake either…
VIN: SAJDB1AV7KCK61608
I feel like the damage is down now though since all of the services are late which is going to seriously impact any eventual re-sale, especially at higher miles/age?Your right, it’s out of sync, if you look into the OSH and select service information you can view each service/year, select view and you will see the tasks for each particular service. I can see that the last service was actually a “prep for sale” whereas year 5 service also has a spark plug change. They will be fine but it means you’ll have to consider sooner rather than later. Thought it strange to miss the first one but then it would have been due to Covid lockdown, lots missed in 2020. So not a big issue if you view any tasks you believe haven’t been completed and get them to do it now before you go ahead. Nice colour![]()
