IvoDC
I am in the process of installing a charging port in the luggage space of my car (F-Type coupe, MY21). To do this I partially pulled off the left panel.
Under the rear driver's side window (the small triangular window) I can see what appears to be a small water ingress tray. A small black rubber tube is connected to it (8mm outer diameter, length ca 25cm). Positioned a bit behind the drivers seat. But the other side of that tube is not connected to anything. when I blow in that tube the air escapes somewhere on the inside of the rear window. I'm afraid I accidentally pulled that tube loose from somewhere.
Can someone tell me where that tube is supposed to be connected to? Or is it just hanging down?
Thank you for your input.
