Sandytim said:I donāt hate the p300 but I fail to see how the benefits outweigh the negatives.
The f type is a compromised car. Small cabin space, smallish boot, wide for U.K. roads, difficult to park, and quite hard to get I and out of.
Yet with the V8/V6 you have an engine so nice that overrides these problems.
So with the P300 you keep the negatives without the positives of a real power plant.
The weight advantage is just a red herring because itās not lightweight in the sports car world and a when a RWD V8 comes at 1650kg then the difference is not worth a jot.
The fuel consumption on a P300 is also pretty disappointing.
So the only reson to buy a P300 is just for the looks. And that for me is not enough.
It's certainly something you have to advise them about, or risk failed payouts, policy cancellation, etc. should something unfortunate happen.ianp said:I am considering doing the map re-vamp but does it affect insurance etc?
cj10jeeper said:Sandytim said:I donāt hate the p300 but I fail to see how the benefits outweigh the negatives.
Totally agree with your comments here and I certainly also don't hate P300's, rather it's not for me with all the advantages of the larger engines (noise, power, smoothness, supercharger, etc.:
Weight difference from 1525kg is tiny at 52kg Vs the V6 at 1577kg. If you wanted a lightweight sports and really cared then a Cayman at 1360 kg (165 kg less than F Type) & mid-engined is so much better or a Lotus (I'd never buy either though)
Fuel economy is no better based on comments made
Engine is a relatively nasty raspy 2.0 turbo that's much more stressed at 150 bhp per litre Vs the alternatives at a c110, needs revving to perform (relative to a V6 or V8)
I can however see why to buy for BIK, insurance costs, purchase price, etc.
Sandytim said:The f type is a compromised car. Small cabin space, smallish boot, wide for U.K. roads, difficult to park, and quite hard to get I and out of.
Madpig56 said:Sandytim said:The f type is a compromised car. Small cabin space, smallish boot, wide for U.K. roads, difficult to park, and quite hard to get I and out of.
Smallish boot? I think thatās an understatementā¦ā¦.tiny boot would have been more realistic.
JonGreen said:A question, are the flat bottom steering wheels smaller diameter than the standard ones or just at the obvious points?
scm said:Madpig56 said:Sandytim said:The f type is a compromised car. Small cabin space, smallish boot, wide for U.K. roads, difficult to park, and quite hard to get I and out of.
Not tiny at all, it's plenty big enough for my needs. But I did choose the coupe.
As for "hard to get out of" - that's only because you want to stay in it and drive it!
