When F O/S wheel off I cleaned up some corrosion behind a joint box. Road gravel collecting over time. Had a look on wiring drawings to check what the heavy Blue wire is, but could not locate. The nut wont come off, so cleaned up and used ACF-50.
The cover “clips” on, but lid doesn’t fit great. Fitted tie wrap. May be worth checking if you have similar poor fitting lid.
When re-fitting is used small spacer to stand off the plastic box to allow the small gravel and water to run off behind the box.
