im sure this must have been covered before but i cant find anything specific.
Im in the process of buying a 2017 build 400 sport roadster. It has the 8" harmon kardon system.
I want apple car play , and im assuming this needs to have a module fitted?
The f type im replacing is a 2013 roadster with a bosch system, that required the dash trim ,trim at side of transmission tunnel and trim behind the seats to be removed to install a car play module , not a straight forward job. Does anyone know if the later cars require the same or is it just the dash trim that needs removing?
