MajorTom
So coming back to the facelift/MY18+ DRL issue... since that other thread with lots of good info on the issue has been removed I'm adding this thread. Thanks to the info from Tim we all know what the problem is and what the solution hopefully will be.
Until the repair solution is available, what do we think is the best course of action to avoid getting the issue or limit the progress of the dimming on cars where the DRL has started to dim?
If I recall correctly, putting the lights in sidelight mode or turning on the headlights dims the DRLs compared to when the lights are in auto mode with only the DRLs on. That should presumably reduce the heat produced by the DRLs and slow down the progress of the dimming. Right?
I think it looks best to run the car with the headlights on because the DRL is less obvious then and the car is more visible than running with only sidelight DRLs. The question is only if the heat produced by the headlight LEDs could have any negative effect on the DRLs and contribute to the DRL's melting/fading issue even if the DRL operates with reduced intensity. Any thoughts on that?
At least from the outside, the lights don't seem to get particularly warm. I took the car out for a one hour blast the other day with the headlights permanently on. Directly after the headlights were cool to the touch so nothing seemed to be particularly warmed up.
