Cost of Diff oil change
  • Start date Start date
Just changed the oil on my open diff. Fairly straightforward with some access a bit fiddly. I also cleaned the breather on the top of the diff. It's little yellow cap that clips on. Removed it and cleaned the bore with a cable tie.
Only one question for you all!
From what I've found the tightening torques for the filler and drain are the same at 27Nm. Is this correct?
The reason I ask is the drain plug felt right at 27nm with where it finished and clicked out. The fill plug however, felt like it was going to go on forever and I stopped when it had gone past the flush point. (Further than where it was when I undid it.)
The two plugs are significantly different sizes to each other and if 27Nm is correct for one (drain), I'm struggling to accept it's fine for the other (fill).
