Should the coolant measure be the same regardless if the engine is hot or cold?
The other day I noticed a slight occasional hiss coming from my 2016 V6s when cooling after a run out.
I decided to keep an eye on all the fluids to see if there was a leak. When the engine has cooled for a good few hours then the measure is between min and max level in the coolant tank.
But if I look straight after a drive, the coolant tank appears almost empty...stays like this for at least 40 minutes. Is this an issue?
