Convertible drain tubes
chicb
Does anyone know where to access the drain tubes for the convertible roof. Just wanting to make sure they are clear. Noticed that after washing & putting away in the garage there was more water on the floor behind the drivers side rear wheel than passenger side. Assume this is the drain exit.
Funnily enough I was just noticing that mine looked nicely even yesterday lunchtime when I grabbed a quick lunch break.
The water runs off the roof into the rubber channel below the rear window - it has cut-outs just inboard of the boot lid each side and the water runs into the boot "moat" surround and to the rear where it goes under the black plastic trim strips - the drain pipes are located under there.
It should be relatively easy to remove the trim but you could always start by pushing a suitable tool such as a piece of cable up the drain tube from the bottom outlet first - that should dislodge any small bits of leaf and crud and you can pour water into the boot surround to flush it out.
Thanks for that, just the reply I was hoping for, will try the cable first, rather than dismantling anything :D
