Android Auto Usability Questions
scz4
Afternoon,
I've only just started using Android Auto after buying an Bluetooth adapter which works really well. It's a 2021 P450.
My first question is how do you flick between Android Auto and the standard entertainment system, other than physically disconnecting the adapter? Perhaps I might want to change the dynamic drive configuration, change the audio options, see the camera....
Second question is, can you turn the screen off when using Android Auto. I use this standard feature all the time when driving at night.
Thanks in advance.
G
Press the four dots in the bottom right corner to bring up the menu, you may have to do this twice. Select the jaguar logo.
You can still use all your AA media from the Jaguar home screen.
Not sure about your second question.
Regards
Maybe try the Mode button on the steering wheel. I use Android Auto via USB and Mode does the trick to flick between AA and the radio.
