Swapped battery last weekend on MY2017.
Tried to do everything according to the book but still had some issues.
Opened bonnet, doors and boot and waited a good 15-20 minutes. (You'll see when the interior screens, lights etc goes into sleep)
Connected a CTEK CS One on "supply" mode under the bonnet.
Disconnected the old battery and swapped for a new one. (I could see on the CTEK comfort panel in the boot that there indeed was power feed even with no battery)
Then removed the CS One and connected Icarsoft v3 JLR to do the BMS reset.
Did so and then as per the workshop manual, started the car and let it idle up to working temperature.
Shut down the car but still had the battery is low please start the engine.
Closed and locked everything and spotted that the warning triangle didn't shut down.
Repeated everything again, with the same result.
My last option was to actually lift the negative without any backup power, this solved it and low battery warning vanished.
Don´t know if i were to clever with constantly supplying power to the car that it didn't realise that i swapped battery.
Well all sorted now...
Oh and some useless information.
Old battery was the factory one, about 70% health and 96% charged when the car started to warn about low voltage.
(Always kept on a CTEK MX5 but now replaced with a CS One throughout the Swedish winter)
