Hi all I was wondering whether or not any of you with F Type convertibles have had this problem?
I have a 2014 V6S convertible which, on the whole, has been pretty good over the 3 + years I have owned it.
Yesterday as the sun was shining the roof was as usual lowered without issue.
When I arrived home I pressed the roof close button, the wings opened to the vertical position and then nothing.
The roof will not move up or down, apart from the wings it is in the down position.
Thinking that a fuse may have popped I found the passenger floor well fuse board without too much trouble and that fuse was OK.
I eventually found the passenger side wall fuse board, is that well hidden, and the 2 fuses in there were OK.
I looked at the manual and see that the roof can be raised using the toolkit but for the life of me I cannot locate the allen headed screw to unlock the roof. The manual picture seems to imply it is between the seat head rests at the front of the retracted roof! Anyone ever looked and found it?
If anyone has ever had a similar problem and found a way to restore motive power please post up. My local Jag dealer has said they will give it some priority when I get it to them but wondered if a bit of DIY was practical.
Thanks Dave
Thanks Dave
