Dave Brend
Hi - thought I’d share my experience of 2 months of pain after cracking my transmission sump cover on a road plate loosing oil and coming to a standstill.
I had an Indy garage do an initial sump cover replacement and refill with Jag OEM oil - which cost about same as liquid gold!!
Transmission then develops an intermittent slipping issue in low gears, typically when pulling away from a junction. Three diagnostics later with “expert” pro register ZF transmission specialists - all said needs a new transmission. One said do a relearn reset - which I did and although it improved the feel, the slip issue was still there.
Went to Jaguar main dealer - end result was 4 litres (allegedly) of top up oil! Touch wood that seems to have completely solved the issue and at c.£500 is a huge relief!
Lessons I learned - 1) don’t trust transmission experts even if they are ZF Pro certified. 2) every so often do a relearn reset as it makes a big difference. 3) if you crack your sump don’t drive as I did until it stopped - hopefully I did no mechanical damage, but I could have done! 4) if you see OEM transmission fluid going cheap - buy it!
Now hopefully that little F-Type drama is over and I can enjoy the car..
