Winter lock up
NAC63
Cleaned, sorned and locked away till next year, as I'm off away until February now. :D
Looks mint. [emoji106]
Determined to drive mine as much as possible over the winter but the grimy, salty roads do mean a wash after pretty much every drive [emoji849]
Sent from my iPad using Tapatalk
Sorned mine last week too. I thought why not, use the new Range Rover over winter and save £50 a month of tax, that'll be fine, I won't miss it. Sunny weekend and I'm chomping at the bit to drive it!! It's going to be a long winter!
Get an indoor cover, makes a big difference, you also forget you have it :lol: I also put dehumidifier granules inside & add 10/15psi to the tyres, full tank of fuel & fuel stabilizer & spray the discs with Atom mac. Don't apply parking brake. Ctek as already mentioned & I never lock it either.
I have a cover but it's a bit embarrassing as it's off my old Porsche 911 with the logo on the front. So no pics lol
JurassicF said:
Isn't that front end just gorgeous! So much nicer than the latest release😁
I agree 100% better. Mine is on H & R springs with 15mm spacers too which I think makes the car look spot on in my opinion ,without the large gap between wheel and arch.
@NAC63.
So you do not have a functional suspension anymore ? I just raised my tire pressure to 3 BAR as there was mostly
wear on the edges, not in the centre. This points to low pressure.
The first thing I noticed was every sandgrain on the road seemed like a brick... .. how do you experience that ?
Dan_Veluwe said:
@NAC63.
Yes I still have the active suspension just the springs have been changed. I use dynamic mode as I like the hard setting, as for wear i had the 4 wheel alignment done on the hunter system and its spot on, it just sits so flat on cornering now with no roll.
3bar :shock: surprised your not bouncing down the road. Get a 4 wheel alignment done .
No problems with 3Bar, ride is a bit harder but performance and roadholding didn't change at all. :mrgreen:
