DanGrimmer
Hello! New to the forums here, so hi everyone.
I’ve had my 2015 F-Type V8 R for just over a year and recently I’ve noticed a vibration (car has done 59k mikes). It’s bizarre because it only appears under hard, kick-down acceleration at around 70mph and lasts up to about 85mph then tails off. It feels like a shudder/judder from the rear of the car when it ‘squats’ down under acceleration.
Things I’ve done (which I know wouldn’t fix it, but thought why not try)
- rear diff oil change
- 4 wheel alignment
- 4 wheel balancing
I’ve just had it checked by a local garage who has confirmed that he felt the vibration too; that’s good I suppose. What’s bad is that he said there was nothing obvious he could see or feel under the car… the only thing he said was that there was slight play in the driver’s rear halfshaft at the diff end, and a small amount of oil misting but not an obvious leak.
The garage seemed reluctant to start stripping down to check further into the mechanicals (to check rear UJ and propshaft bearing), so I’ve left it for now. The car isn’t undriveable at all and at low speed, hard acceleration there is no vibration at all. A bit of a weird situation.
Has anyone experienced this at all? Any advice would be hugely appreciated.
Thanks!
- 4 wheel alignment
- 4 wheel balancing
Thanks!
