Servicing after 10 years
Kempy1
Hello all,
I've got a 2013 V8S convertible with 40k miles on the clock.
The last service I had was massive as the previous owner didn't get the 10 year service done.
It was belts, brake fluid, gearbox service/kit replaced, coolant, LSD oil changed, etc..... basically pretty much everything. It was rather expensive, but needed to be done. Think it was in the region of £1500 at an independent in Norwich J-Cat.
They said not to bother with the plugs as with that mileage it's pretty much pointless.
I guess my question is, what would the next service entail?
The guides I've seen only go upto 10 years and mine will be on the 12th, the old gal is getting on a bit now, but she's not missed a beat in my ownership.
Vaguely remember reading that you start the 10 year cycle again,
So 11th service is the same as 1st
12th same as second, etc etc
Dunno if that’s correct
Agree with S1. Just begin the cycle again. As our cars age it may be wise may to consider other bits.
I’ve having supercharger overhauled, plus new water pump, thermostat, all coolant pipes. Not needed but to keep on top of potential issues.
Will only be basic oil service, filter next year.
Had plugs swopped at 5 years old but garage again said I don’t do enough miles to justify replacement.
