I have imported a MY2015 F-type from Canada to Norway, and would like to replace the SAT-radio with DAB. I am aware of the need to update sw in the car.
My plan is to replace the SDARS-unit with the DAB-unit, and install the DAB antenna (in trunk) with the OEM DAB antenna amplifier.
I have som questions, and hope someone have done this before:
- Is it possible to use an aftermarkesd windscreen mounted DAB antenna instead og the OEM version?
- Can I use the antenna cable from the SDARS-unit to the DAB antenna?
- Are there any other challenges with this retrofit?
