Remus Exhaust details
probbins2000
Hi
I decided to fit a Remus CAT back exhaust system to my 340 V6 F-Type. When I was looking into different systems I found it difficult to find any detailed information regarding noise levels / loudness etc. The best information I got was from other like minded forum members, so thanks to you all.
So with this in mind I decided to carry out a totally unscientific experiment for my own curiosity and maybe too inform others.
Please keep in mind that I am not a sound expert but just someone with a decibel meter purchased from amazon.
This is just a bit of fun.
I have attached the following readings that I have taken before and after.
Method
Purchased a cheap sound meter from amazon “Sound Level Meter, Tacklife MLM02 Sound Level Meter, Measuring Range 30-130 dBA,”
I took three readings for each test and what is shown is the average of these.
Used the same conditions and location for before and after readings
Start up readings (warm engine) taken behind the car 1.5m from exhaust tips
Stationary rev test to approx. 5k revs, basically blipping the accelerator to full
The above rev test overwhelmed the meter at anything less than 8m distance so this was used as a control point.
In cabin readings taken between seats at head level under normal cruising conditions
0-60 cabin reading was maximum acceleration using same method
Car windows up and audio off.
Active exhaust means Dynamic mod with active exhaust engaged
Normal “D” not sport “S”
Conclusion
I am only a few days in to this but my initial conclusion is “ Glad I had it done”
If I had to describe the result I would say, “the Remus on normal mode is similar or maybe a little less than the OEM exhaust in dynamic. However, with the active exhaust on with the Remus exhaust it’s a whole new ball game”.
Other observations
The tic over burble whilst not significantly louder has a much deeper tone.
The build quality is very good
Took just under two hours to install (authorised Remus supplier and fitter)
Kit is complete with all clips mounts and extensions to vacuum pipes
Tail pipes I chose were chrome option but are easily interchangeable
There is a supplier YouTube clip of the exhaust system in action, but doesn’t really do it justice.
https://www.youtube.com/watch?v=09sl33UAqCs
Note
It should be noted that the decibel scale is not linear, for example 100db is about 8 times as loud as 70 dB.
http://www.industrialnoisecontrol.com/comparative-noise-examples.htm.
I notified my insurer of the modification and it attracted no additional premium
Hope you find this of interest and useful. Again, I must point out that my readings may contain errors and are only my tool shed experiment and do not reflect any actual Remus or Jaguar factory information
Hi,
So overall, are you glad that you made the swap to Remus? (seems like it reading your posting).
Can I ask who fitted the exhaust? As I am in the position of needing a new exhaust and don't know whether to go stock or go aftermarket!
Seacourt
Hi Seacourt
I live in Kent so I went to a performance shop near me called JF Automotive
https://www.jfautomotive.co.uk/?gclid=EAIaIQobChMIkqazsc7g3gIVSuh3Ch1lwQCzEAAYASAAEgINpfD_BwE
Not sure of your location but I would recommend
I'm off to David Appleby Engineering on Monday next week to get a Velocity AP cat-back fitted, can't wait for a bit more noise!
probbins2000 said:
Great, let us know what the results are like
The results are in. It was a 90 min drive back from DAE and my cheeks were hurting by the end, cos I smiled like a loon the whole way back :)
Fuel economy wasn't great either as I did the motorway section in 6th rather than 8th, just because it sounds so damned good. I'm chuffed with the result.
I wouldn't say it's any louder when the valve is closed, it's just a different tone (and a pleasant one at that), a bit more 'cultured' almost, but it's also not "Chav Loud" when the valves are open although certainly louder than stock. But it really barks when you gun it with the valve open, plus you get plenty more pop and crackle too.
It's exactly what I was looking for...we're not talking "Max Power"-type tuning here, just a bit different and with a voice that's throatier enough compared to standard to be noticeable but certainly not outrageous.
Was also really happy with the workshop - James @ DAE is a lovely bloke, let me have a poke around the GT4 F-Type racers that they maintain there (posted pics of these in the Gallery section). I'll definitely be going back there at some point for the tune and pulley kit, but I want to enjoy the exhaust as it for now before doing anything more serious with it just yet.
They also do induction kits plus a "whine inhibitor removal" kit which I'm tempted by...JLR went to some lengths to suppress the noise of the supercharger whine and the DAE kit undoes that and gives it a bit more of a voice... :)
Really crappy pic below, sorry for quality but my phone didn't like the bright workshop lights.
This may be of interest to someone if still available ....
https://www.ftypeforums.co.uk/viewtopic.php?f=18&t=2831
I would agree with the comments regarding a deeper yet not excessive tone on tick over, nice bark on start up, and it gets a bit naughty in dynamic mode ....
[/quote]
[/quote]
Glad you are please with the results.
I’ve fitted a Remus cat back and can say normal running around is just as nice as stock, then put my foot down and hell is let loose it’s nuts I expect to see the Devil in the mirror ripping up the road and the overrun well it sounds like war, smiles from ear to ear
Hi all, new to the forums today. Torn between Remus and Velocity AP. As i've not heard either other than youtube its a tough one. Looking for more volume as find the stock to quiet but at the same time the stock does have some lovely overrun sounds. Hopefully theres some opinions out there as short of buying both and trying its hard to know what to go for.
Ap velocity valved or pop some soprtscats on
Their sportscats and my standard backbox is valves closed like stoxk but open the valves and its awesome
I do not have my f-type anymore but I made this short video of the car with the Remus exhaust before I said goodbye.
it may be of some use if you are deciding which exhaust option to go for
https://youtu.be/-29Loo4BjYY
Which Velocity exhaust did you go for ? Touring or Super Sport??
Cheers
Hi at all. I have ordered a remus catback exhaust system to my v6 p340.
Does anyone know how to fit the middle pipe to the cat pipe? There are no mounting screws or clips in the package.
Does anyone have a photo or describe which clips i will need?
I have a my20 so it has gpf fitted if it does matter.
I hope some one have informations about it. The mounting instructions of remus doesńt help me further.
