Rear wheel offset advice
Jimmyrn85
Hey clever folk...
I've got a 2017 R with standard 20inch wheels, being a 10.5J ET38 on the rear.
I'd like to stick Maelstrom's on my car, which are a SVR standard wheel with a 11J ET54 at the rear.
With the Maelstroms being "further in" if I stick a 20mm spacer on the rear will it be the equivalent to +4mm offset outwards compared to my original wheels?
How does it work with them being slightly wider? ie in terms of spacing.
Cheers
The US forum has a number of posts where people have fitted Maelstrom wheels, e.g.
https://www.jaguarforums.com/forum/f-type-x152-72/just-got-my-maelstrom-wheels-174416/page3/
Your wheel is circa 13mm wider and offset by an additional 16mm, so the inner rim is 3mm further in, therefore a 10mm spacer will take them 7mm further out than your existing rims.
I believe they are either flow cast or forged too, so may well be a little lighter than your existing rims despite being bigger - win win 😎
I had assumed the 13mm wider is + 6.5mm on each face from the centre. Making the front face circa 9.5mm recessed. Although on the pictures from the US it lookes more exaggerated.
I expect someone on here has them.
