Hello everyone,
I’m from Japan and I apologize in advance if my English is not perfect.
I own a 2015 Jaguar F-Type Coupe S (3.0L V6 Supercharged). Recently, I encountered a very strange issue: raw gasoline suddenly came out of the exhaust after about 15 minutes of idling. I’m hoping someone here has seen something similar or can offer advice. Here’s the timeline of events:
1. Initial Water Leak & Misfire:
• The check engine light first came on due to a water (coolant) leak and corrosion. Diagnostics showed random misfires, primarily in cylinder #5.
2. Repairs for Misfires:
• We replaced all the ignition coils and spark plugs. However, upon test-driving, the engine had almost no power and made a loud “bop-bop-bop” noise from the left-side exhaust. We canceled the delivery and continued investigating.
3. More Repairs (White Smoke & Sensors):
• The left bank (V6) started blowing a significant amount of white smoke from the left exhaust. We suspected sensor failures, so we replaced the crankshaft sensor and camshaft sensors.
4. Supercharger Replacement:
• The mechanic also noticed a rattling sound in the supercharger, so we replaced the supercharger with a rebuilt unit.
5. Sudden Fuel Dump from Exhaust:
• After these repairs, the engine initially ran smoothly. But when idling for about 15 minutes to warm up, the check engine light came on again, and then raw gasoline started pouring out of the exhaust. It was definitely gasoline (strong smell, not water). Fuel dripped heavily from the rear muffler area, and the mechanic immediately shut off the engine for safety.
My mechanic has 30+ years of experience (including racing engines) but has never seen fuel literally flowing out of the exhaust like this. We are trying to figure out if there is a known issue specific to F-Types or Jaguars that might cause this.
I found an older thread titled “V6-S dumping raw fuel” ( https://www.jaguarforums.com/forum/f-type-x152-72/v6-s-dumping-raw-fuel-199707/ ), but it doesn’t seem to have a conclusion. If anyone has encountered a similar situation or knows any possible causes, I would really appreciate your insights. We have invested a lot of time and money but still can’t drive the car.
Thank you very much for reading and for any help or advice you can share!
Japanese(日本語)
2015年式のジャガー F-Type クーペ S(3.0L V6 スーパーチャージャー搭載)に乗っています。最近、非常に珍しい深刻な問題に直面しました。エンジンを15分ほどアイドリングして暖気していたら、突然マフラーから生のガソリンが噴き出したのです。もし同じような症状をご存じの方、あるいは解決策をご存じの方がいらっしゃれば、ぜひアドバイスをお願いいたします。
これまでの経緯は以下の通りです:
1. 最初の水漏れ&ミスファイア
• エンジンチェックランプが最初に点灯したのは、水(クーラント)の漏れや腐食が原因でした。診断機で調べると、主に5番シリンダーでミスファイアが検出されました。
2. ミスファイア修理
• イグニッションコイルとスパークプラグをすべて交換しました。しかし、試運転時にエンジンがほとんどパワーを出せず、左側マフラーから大きな「ボッボッボッ」という音がするため、納車を中止してさらに原因を調べることになりました。
3. さらなる修理(白煙&センサー交換)
• 今度は左側マフラーから大量の白煙が出始めました。センサーの不具合を疑い、クランクシャフトセンサーとカムシャフトセンサーを交換しました。
4. スーパーチャージャー交換
• スーパーチャージャーからガタツキ音があったので、リビルト品に交換しました。
5. マフラーからガソリン噴出
• これらの修理後、エンジンは初めは快調でしたが、15分ほどアイドリングして暖気していたところで再びチェックエンジンランプが点灯し、その直後にマフラーから生ガソリンが大量に出てきました。整備士がすぐにエンジンを切りました。ガソリンの強い匂いがあったので、水や凝結とは明らかに違いました。
30年以上の整備経験を持つメカニックも「直接ガソリンがマフラーから流れ出てくるのは初めて見た」と驚いています。
F-Typeやジャガー特有の既知の問題なのか、過去の事例や原因があれば知りたいです。
過去に “V6-S dumping raw fuel” というスレッド(https://www.jaguarforums.com/forum/f-type-x152-72/v6-s-dumping-raw-fuel-199707/)を見つけたのですが、結論が出ていないようでした。同様の問題を経験された方や、原因をご存じの方がいれば教えてください。すでに多くの時間とお金をかけましたが、まだ安全に走行できる状態ではなく、非常に困っています。
何かアドバイスをいただけると大変助かります。よろしくお願いします。
Japanese(日本語)
これまでの経緯は以下の通りです:
1. 最初の水漏れ&ミスファイア
2. ミスファイア修理
4. スーパーチャージャー交換
5. マフラーからガソリン噴出
