Hi all. I've been experiencing a really annoying vibrating / rattle sound going over bumps and also at certain rev ranges with the exhaust valves open. I think i have isolated the source to the rear of the centre console assembly (ie near where the panel between the seats is covering all the audio visual wiring). Its not the panel that's the issue because it happens even when I have pulled it off. I have lifted the centre console slightly upwards and it seems to have temporarily fixed the issue but I suspect it will come back. Has anyone had a similar issue / can advise things to check? Thanks
