Morning all,
More woes with the f-type
Recently had 2017 v6s in to sort a coolant leak (that they never found :-( ) and as part of that they said it had a bad coupler - think they called symposer? Anyway, said could be sorted under my extended warranty .
Got it back and seems worse… rattle obvious at idle feels like can get to get quieter if partially lift off throttle - maybe load related on the supercharger belt.
Did wonder if it’s new part thing - so run for a month or so but if anything getting worse
Is there anything that can go wrong on fitting of the couplers? - hope not in backwards!
Doesn’t do ( and never has ) done the clunk when switching off.
Will get it back to them…just don’t want to be fobbed off (like the coolant problem) and said is normal.
Anyone got any experiences?
Si
Si
