mickjaguar said:According to the manual, you should be able to swipe right ...
pirateprentice said:It's the one thing that is completely daft - on every other car I've owned I could select screen/passenger/footwell airflows from direct controls, which made sense because I would want to change them quite often. Now they are buried in an 'advanced' settings menu it's more like change it for summer/winter only.
Kev said:Has someone upgraded the head unit to the later 10.2” as a retrofit to replace the standard 8” unit as you can lose the climate controls when that’s done?
MajorTom said:... as far as I know most if not all MY18 cars came with the 8" screen
mickjaguar said:Ok so I've just had a quick look at my car. Swipe in the opposite direction of the other menus, until you get to a screen called MyHome (not Home which is the main screen). Then press and hold anywhere on the screen and you should see lots of boxes with a + symbol. Press one them and you should get some sub menus to choose the available features.
That's for the OEM fitment and it's all in the manual, but admittedly it's a bit vague.
