MajorTom said:- windows - check for vertical scratches
- the diff - check for any grinding or whining noises from the diff
MajorTom said:If they are covered depends on what kind of warranty you have. A full fledged extended JLR warranty (at least here on the continent) covers all of that and much more and dealers are happy to replace parts under warranty at the slightest suspicion of something being out of the ordinary. Easy money for them. For instance I recently got a new diff under warranty due to a whine which probably wasn't a real issue and was just a bit louder than normal. In my last Jag I got a complete new supercharger under warranty (which wasn't actually necessary) just to see if it would help with another issue I had.
Since the OP only has 3 months of warranty it doesn't sound like a JLR warranty and the conditions may be a bit restrictive. I've read about all sorts of odd warranties in the UK that exclude lots of stuff so if it's not a warranty that comes with a JRL approved car I'd check the conditions very closely.
stevejag said:MajorTom said:If they are covered depends on what kind of warranty you have. A full fledged extended JLR warranty (at least here on the continent) covers all of that and much more and dealers are happy to replace parts under warranty at the slightest suspicion of something being out of the ordinary. Easy money for them. For instance I recently got a new diff under warranty due to a whine which probably wasn't a real issue and was just a bit louder than normal. In my last Jag I got a complete new supercharger under warranty (which wasn't actually necessary) just to see if it would help with another issue I had.
That is very promising and makes me want to take out an extended warranty when picking up mine this saturday .
