Car 10300.
A V8S convertible in Italian Racing Red.
5 previous owners.
The first from Barnet for first 3 years, probably on a PCP. Then the others which based on history would be
2nd owner in London.
3rd in Coventry
4th in London
5th (current) in Kent.
Service wise, all ok from 2015 to 2019 and fully itemised. Then a gap until 2022 and then a gap until current service. I am presuming this is used approved and will be sold with 1yr Jaguar warranty which is why the 9th service recorded earlier this year they did everything including supercharger and accessory belts.
Clear on PNC, and although probably slightly over priced, might be worth it as expensive 9th service complete and hopefully that 1yr warranty as well.
MOT history. Well the usual wipers and tyres although why would you drive around in your 186mph sports car with a rear tyre down to the cords and the other approaching minimum! And then only change the illegal tyre. And then end up with a rear diff leak.
It looks nice. Check out everything works, double check you get the full Jaguar warranty and do all the usual checks.
