LED headlamp adjustment
Derivative
Dear All,
Before I go fumbling around in the wet, cold and dark trying to do this...
Does anyone know if and/or how the LED headlamps are adjusted?
I had to have a faulty headlamp replaced (DRL was the problem) and they haven't set the levels (ridiculously low).
I don't know if it's one of those things that's coded to the car and/or needs Pathfinder to set the levels correctly.
If it's an easy DIY job then it'll be less agro than having to take it back to the dealer.
This is for original headlights, no idea if LED are similar..
If you search these forums I put up a post and pictures on how to set the aim both X and y axis of the headlight units.
I'm pretty sure they use the same enclosures and adjustment screws as the older units.
I think I would be taking the car back to the dealer that fitted the replacement light unit and ask them to finish the job properly. They should have checked the level as part of the job. Too low and they are not fit for purpose.
