I need please tutorial how to remove ,for the cabrio version, the SRS airbag module. It's not easy like Coupe version , I think i must remove the trim for roll bar to have access to this module.
Thank you!
You can check how to remove the roll bar structure here:
https://youtu.be/eAklx6afwKc
I did this as well on an attempt to install an android auto box - for those it's not necessary anymore, newer versions interconnect in the center tunnel.
Worst part is prying off the speaker covers. Check the tabs on removal, it's easier if you remove them in a certain direction.
