Caprian280
Hi all
Im looking at replacing my battery on my 2019 P300.
Ive seen a Varta A5
Type 019 agm
CCA 850
Ah 95
Clamp type B13
L= 353mm
W= 175mm
H= 190mm
Has anyone fitted one of these or know if it will fit please?
Some parts websites state it does, some state it doesnt.
The ones that say it dont state the A6 varta, CCA 800 Ah 80 (a little shorter too)
L= 315MM ish
W = 175mm
H= 190mm
If i can fit the bigger Ah battery, will it cause any damage to the car as such i.e alternator for example.
Cheers for any advice and apologies for not being up on these things - this is fairly new to me, coming from older cars where you could throw any battery in them within reason, im a little lost of this newer tech
Ive seen a Varta A5
Type 019 agm
CCA 850
Ah 95
Clamp type B13
L= 353mm
W= 175mm
H= 190mm
L= 315MM ish
W = 175mm
H= 190mm
