<p>I have had this problem several times over the past year, but Jaguar cannot seem to locate the problem. I am guessing others have seen this issue but not reported it.</p><div> </div><div>Scenario 1:</div><div>Every so often when the car pulls up to traffic lights it goes into start stop mode, when coming out of stop mode the gear letter on the stick and in the dash starts to flash. you can then no longer select a gear, the car wont move. The only way to resolve this is to turn the engine off and on again.</div><div> </div><div>Scenario 2:</div><div>Starting the car up, the engine starts and the vehicle is in Park. Select a gear (reverse or forward its happened in both cases) the car seems to go into gear and after an inch or so the gear box and display started to show a flashing letter and the car stops but the engine is still running. You can then no longer select a gear (all gear letters flash) and the only way to get moving again is to press the stop button then start again.</div><div> </div><div>Anyone had a similar problem ?</div><div> </div>
