alistair64
I realise this topic must have been covered a hundred times before :roll:
Ok, as I'm getting a small amount of white smoke from the right-hand exhaust when cold from my V6, I'm thinking that some injector cleaner in the fuel tank might be called for.
However, there are so many differing stories of the effectiveness.
I would probably use Techron PEA at around £15 a bottle, so I'm wondering if anyone has actually used injector cleaner to sort out the white smoke problem and seen any visible improvement.
What I really want to know is whether anyone has definitely seen cleaner exhaust gases after using some.
I know, only £15, but if no-one has actually seen any difference I'd rather put the £15 to better use... like in the fuel tank.
Thanks.
Thanks.
